Extruder not pulse
pcomud
Extruder not pulse
Post by pcomud »
Hi.
My prusa I3pro In Extruder not pulse.
I use a measuring oscilloscope. There are no signs in the extruder. Using an oscilloscope to measure the x, y, z are billed as a regular signal.
Who knows, please help me. I have taken the clip may not be sharp, sorry. Can someone explain or help me?
Link:--> https://youtu.be/VGOtXLhxz04
]Sorry for the language I'm not good at.
Thank. :(
pcomud
Re: Extruder not pulse
Post by pcomud »
Hi.
I want E0 to use pin for E1 and pin for E1 use pin for E0. I suspect E0 pin command has a problem inside ATMEGA2560.
How do I edit the code?
Thank.
Gingko
Post by Gingko »
It should be mentioned that the extruder only works when it heats up to over 170 degrees.
If you want to use E1 slot, refer to this post:
viewtopic.php?f=20&t=18020
pcomud
Post by pcomud »
Gingko wrote: Fri Jul 27, 2018 5:20 pm It should be mentioned that the extruder only works when it heats up to over 170 degrees.
Hi Gingko
I use a multimeter on my GT2560 board, it does not match any pin at all. Show on the attached picture red text is the pin that I measured.
Thank.
My GT2560 board for I3pro W.jpg (172.58 KiB) Viewed 7568 times
My pin for GT2560 I3pro W.jpg (148.74 KiB) Viewed 7568 times
