X Belt Tension
BennyBoyW
X Belt Tension
Post by BennyBoyW »
Hi all
Is there any instruction for tightening the x axis belt on the A30?
SirSunshine
Re: X Belt Tension
Post by SirSunshine »
Been wondering about that myself. Via Youtube on the CR10, it appears to be on the right hand pulley. Not so on this printer and not sure how you'd do it. There may be room on the right side of the hotend to put a tightener. When moving all the way to the right, there is still a good bit of space left to accommodate the tensioner.
SirSunshine
Re: X Belt Tension
BennyBoy,
I printed these last night and put one on my X axis belt.
https://www.thingiverse.com/thing:10082
I scaled the Z axis up only by 20% a few times to make some of different sizes. It tightened the belt and helped quite a bit. Surprisingly on the bottom infill as well. Probably needs a bit more however as it's still not quite there.
2018-09-18 07.19.39.jpg (167.31 KiB) Viewed 12041 times
2018-09-18 07.20.09.jpg (161.17 KiB) Viewed 12041 times
Bottom of cube before and after
2018-09-18 07.19.17.jpg (193.07 KiB) Viewed 12040 times
Lexan
Re: X Belt Tension
Post by Lexan »
loosen the screws, pull the axe, hold it tight, fasten the screws
dekes1
Re: X Belt Tension
Post by dekes1 »
Lexan wrote: Fri Oct 26, 2018 11:51 pm loosen the screws, pull the axe, hold it tight, fasten the screws
This is the correct way to tighten the belt, but there's a better way :D
Since the A30 is a CR-10 clone, nearly all the CR-10 upgrades work here as well. I printed out this x-axis adjuster and it works great. I also printed out that author's Y-axis adjuster as well
https://www.thingiverse.com/thing:2854971
Lexan
Re: X Belt Tension
Post by Lexan »
nice idea
MorningsideSanitarium
Re: X Belt Tension
Post by MorningsideSanitarium »
How do you get this tensioner installed? It is already too tight to pull together when I try. I don't even have it far enough to put the bolt through the bearings and it's already so tight I fear it's going to snap. I don't understand how everyone is using this tensioner upgrade.
