Large z-wobble, x-y axis inflation
Hi there.
I've a problem with verticals objects.
They are printed with horizontal deformations and appears like a cyclical inflating/misalignment over x and y directions.
I need help.
Thank you.
I need help.
Thank you.
Re: Large z-wobble, x-y axis inflation
Can you post a photo of your model?
Files attached.
Thanks for you reply
- FB_IMG_1533667642697.jpg (151.55 KiB) Viewed 9508 times
- FB_IMG_1533667510793.jpg (301.27 KiB) Viewed 9508 times
Thanks for your attention
- Z-wobble
Did you find any solution to solve this Problem? Because I have this printer for some weeks now and have the same issue, but no solution.
Hi.
It looks as if the axis mechanisms still require calibration, and adjustment.
Read the subforum about the A10 and A30 models there is a lot of information about how to adjust the carriages.
I have now read almost the entire forum, but found nothing that is helpful.
The whole system is free of play, the reels run reasonable, I only print with 30mm/s, I checked the driver voltage, nothing helps.
I am on the edge of throwing the printer in the trash
HI.
Someone wrote that the wheels of the trolley squash when not in use.
Don't throw away the equipment, treat everything as a test of your nature.
