Hi All,
I am new to 3D printing, and thought the assembly would be more difficult than actually printing. I have completed my first item but it is falling apart and looks ver stringy. I think it could either be the Filament is not getting hot enough or the slicer I am using is not correct. If I am totally wrong please can you direct me in the direction of the truth. Please see sample of issues.
James
My first 3d print completed but issues
- IMG_20180826_174611.jpg (217.06 KiB) Viewed 20910 times
- IMG_20180826_174559.jpg (198.66 KiB) Viewed 20910 times
Re: My first 3d print completed but issues
You are right, you are completely wrong.
First of all, I will recommend you to read the forum and find out what others have done in a similar situation.
I have tried many things from this from and no go.
What you have already tried is the best way to cooperate on the forum. You will save time for others.
This problem is a common problem for anyone who starts their adventure in the 3D world.
I have tried increasing the feedrate, from 100 to 204 this is how I got this result. Something's I have noticed my z axis when I home it, it goes up about 0.5m but not down to the stop switch. Also I have tried using STL files from thingiverse and tinkercad.
James
James
You need to adjust the stepper mm of Z axis(Your printer z axis rod it T8)
