Could somebody tell me the name for the J3 "wifi" connector on GTM32 mini board (1x8 pin connector)
It´s not a regular pin connector, it´s smaller.
thanks
Connector type for J3 connector in main board?
Re: Connector type for J3 connector in main board
This connector is smaller, and I am doing some test with ESP3D and work like to pin some cables there, and would not like to solder wires...
Could it be a JST-SH 1.0mm 8-Pin?
- GTM32-1 - copia.jpeg (220.42 KiB) Viewed 8194 times
Re: Connector type for J3 connector in main board?
Yes, it's a regular goldpin connector.
All you need to know about it is raster. In this case it is 1.27mm.
Any luck with this J3 connector and ESP3D?
If yes can tell me what are the pins to use?
Hi.
You will find the answer by browsing the diagram of this electronic circuit.
It is available on GitHub GT.
proyect is stopped until working and stable source code is release on github....
manage to do it on and A20M, but it uses marlin and code is available, not so with smartto code...
