FAQ For Geeetech A10 series 3d pirnter
Locked
Admin
Post by Admin »
Print problems
1.If you find the nozzle no filament out
1)Check your PTFE tube plug is deep enough/Smooth
http://geeetech.com/forum/viewtopic.php?p=88482#p88482
2)Refer to this video clean your hotend
https://www.youtube.com/watch?v=evslMa5Jpc8&t=56s
3)Check the extruder motor direction is correct
If the direction of it is not correct, refer to the part of"Motor"
4)Check the spring of the feeder have enough strength/Too strength of the spring will make the filament broken
Feeder screw.png (1.07 MiB) Viewed 78812 times
5)Clean then gear of the feeder
2.Y axis layer shift
1)Tighten the Y-axis belt
2)Check the vref of the Y-axis motor driver board
For A4988:0.8~1.0V is ok.
If you think A4988 is too noisy, you can replace it to TMC2208
For TMC2208:0.7~0.8V is ok.
If it allows, you'd better add the heat sink for TMC2208(It will overheat if you don't add it)
Refer to this post adjust the vref of the motor driver
viewtopic.php?f=17&t=17038
3.The extruder is very noisy A10M
1)You can add the oil to this area
Add Oil.png (1.41 MiB) Viewed 82198 times
2)You can loose a little for the screws
Loose the screws.png (1.49 MiB) Viewed 82198 times
4.Add the purge bucket for your A10M/A20M
Refer to the link(By cmhnav Feb 2, 2019):
https://www.thingiverse.com/thing:3395883
Purge Bucket.jpg (45.49 KiB) Viewed 79243 times
Profile for Cura+Mixer software
1.Geeetech A10M
http://geeetech.com/forum/viewtopic.php ... 613#p88613
Mixer software
The mixer software is for the dual-multi mixer hotend printer.
You can edit it to a single color/Gradient.
http://geeetech.com/forum/viewtopic.php?f=92&t=61760
2.Geeetech A10
viewtopic.php?f=98&t=61568&p=85872&hili ... son#p85872
Motor
1.Direction of motor:
How to change the motor direction in firmware?
2.Motor works abnomral
Motor’s non-action
Check the endstop of the printer
http://geeetech.com/forum/viewtopic.php?f=17&t=60927
Drivers
Check the USB serial chip at first then :
viewtopic.php?f=21&t=60612&p=81974#p81974
Extruder
1.Extruder
Extruder does not work normally.
2.Nozzle type and hotend
The nozzle type of A10 is m6 thread;
Hotend of A10:
The nozzle type of A10M is m7 thread;
(It is not the standard MK10 4mm inner diameter nozzle.You need to check it at first.The default inner diameter should be 2mm)
3.Hotend clean and nozzle replce
Hotbed
1.Note:
If the hotbed won't heat,you can remove the clamps from the four corners of the hotbed
2.The hotbed thermistor datasheet
viewtopic.php?f=51&t=62055
PID tuning
Tuning refers to the parameters adjustment of a proportional-integral-derivative control algorithm used in most repraps for hot ends and heated beds.
eg:M303 E0 S200 C5
PID needs to have a P, I and D value defined to control the nozzle temperature. If the temperature ramps up quickly and slows as it approaches the target temperature, or if it swings by a few degrees either side of the target temperature, then the values are incorrect.
https://reprap.org/wiki/PID_Tuning
Source
Schematics
Schematic for the old version Mainboard: GT2560 Rev B
Schematic for the new version Mainboard: GT2560 V3.0
Wiring of GT2560 Rev B
GT2560 Rev B2.png (1.64 MiB) Viewed 78816 times
The wires of GT2560 V3.0
GT2560V3 wires.png (2.69 MiB) Viewed 84350 times
Level
1.Video for 3Dtouch/Bltouch on Geeetech A10/A10M
You need to refer to this video upload the firmware to it and adjust it
https://www.youtube.com/watch?v=_RtsZDbR2po&t=59s
2.The manual level
Where to find the firmware and how to install it?
1.You need to upload the firmware via Arduino IDE 1.8.5(Use the 1.8.7 or higher version may cause the motor work abnormal)
viewtopic.php?f=20&t=17046
viewtopic.php?f=20&t=17181
2.Marlin 2.0 & 2.1 firmware (unofficial) Author: marlin developer vertabreaker aka vert
viewtopic.php?f=20&t=69957
Cooling fan:
How to fixed the PWM fan problem?
Updating.....
Locked
