Installing an E3V6 hotend?
anrkii
Post by anrkii »
I purchased a v6 hotend, and printed the mounting parts, and installed it. I could not get it to print correctly no matter what the settings. The V6 has a different thermistor, and from what I have read firmware has to be changed manually in order to set it up correctly. Has anyone done this on an A30?
How is this accomplished.
Forr now the original hot end is back on there.
Re: Installing an E3V6 hotend?
:mrgreen:
I have another suggestion. :roll:
Did you think about replacing the thermistor :?:
It could be much easier. This electronic component is not expensive.
anrkii
Post by anrkii »
The geeetech thermistor is too big for the V6 hole to fit.
apak
Post by apak »
I´ve manage to use a original V6 with no problem with latest fw
Lexan
Post by Lexan »
so far i use an trianglelab v6 clone, and a titan aero clone without any trouble, shure u will need socks bcs the pid tuning isnt made for that but havent anny other trouble
Stocki83
Post by Stocki83 »
Ist there anywhere a documentation😋..? I would like to do this step.
Stocki83
Post by Stocki83 »
I think with the original :ugeek:
