Cura json file for your Geeetech A10M printer
Hi guys! :o
Are you can't find Geeetech A10M on Cura?
Don't worry
Refer to these:
------------------------------ :D --------------------------------------------------
Update:Thanks for @vert's suggestions.
1. We added the G29 for the start code
We added the "G1 Y230 F6000" for the end code( 2019/1/7)
2. We attached the PLA filament profile for Multi_mixer printer(2019/1/23)
3. We set the default filament diameter to 1.75mm and it can work with Cura 4.0(2019/4/7)
4.Thanks for @LisaE‘s suggestions.The profile updated.(2019.4.17)
5. Deleted the "Heating gcode for nozzle/hotbed"in"start code".Added the meshes file.(2019.4.24)
1.Download Profile for Geeetech 3Dprinter
Cura4.0 resources.zip
(158.48 KiB) Downloaded 4669 times
Download the PLA filament profile for A10M
Geeetech Mixer PLA Profile For Cura.zip
(1.82 KiB) Downloaded 4608 times
2. Unzip the zip file then you will get "resources"folder
3.Copy "resources" to the
Cura installation directory
Default:
C:\Program Files\Ultimaker Cura 4.0
3.Import the PLA filament profile for Geeetech A10M
Filament profile1.png (29.2 KiB) Viewed 40748 times
Filament profile2.png (48.1 KiB) Viewed 40748 times
Filament profile3.png (49.75 KiB) Viewed 40748 times
4.Done!Enjoy it!
aamulk
Re: Cura json file for your Geeetech A10M printer
Post by aamulk »
Thanks William for your post and link. I followed your instructions and finally got my new a10m and computer talking. Printing out my first project now. So Far so Good. I am still having an issue with the z axis not being close enough to the bed when it first starts. Any tips?
Hi,@aamulk
You can refer to these
1.Check the heatbed level
Refer to this pic
2.You can use the babystep adjust the z offset when it start print.
trixster87
Post by trixster87 »
For any other new owners, I can confirm it worked for me on Cura 3.6
Wingding5
Post by Wingding5 »
I am new to 3D printing and still figuring out Cura. I had a few questions about the profile.
1. When I imported the profile, It set the Extruders to 2.85mm. Is that what I should keep?
2. In Cura, The Extruder 1 profile is accepting 1.75mm filament. and Extruder 2 is accepting 2.85mm filament.
I tried changing the settings to what I think It should be, Bed at 235 X 235, Extruders with 1.75 mm filament in print profile. But when assigning the materials to extruders, it won't let me assign 1.75mm filament. Can you please confirm if that is how I should keep it?
Devine
Post by Devine »
You want everything at 1.75mm
dionlima
Post by dionlima »
Hello, you also can paste the material files directly on resources/material.
regards
Hogdriver
Post by Hogdriver »
Thanks to the OP for this cura profile! Along with Vert's Marlin 2.0 (I am using build 210, which I understand isn't considered 'stable' on long prints -- along with all other builds for now) I am now getting very nice prints compared to the stock firmware.
I particularly like that I can select which extruder/color to use for each object on the board. Haven't figured out yet how to mix colors... but I'm in a sort of limbo state right now due to hardware problems (see below):
I am still dealing with a defective motherboard issue, which Geeetech has tried to remedy with a replacement... However, the replacement also had issues, and only boots very intermittently and is not stable, so I am back to the original one with the problem of not being able to heat the bed at all. Despite that, I am getting good adhesion on the glass plate with PLA.
mt690ju
Post by mt690ju »
It took a while, but thanks to your JSON file and some dialing in on Cura 3.5, I was able to eliminate my stringing problem and the extruder gear from shaving the filament. I used the two color Benchy for a test since it has some many changes with the two colors. Bleeding was eliminated by significantly increasing the volume of the prime tower. Image
Top View No Stringing
Bottom of Benchy
Bottom of Benchy
SackofFluor
Post by SackofFluor »
Hey Guys,
i just have a quick question. I am using Cura but in general I am a beginner.
I have an A10M and the two coloured test print worked great, mono-colored prints work great as well, i just have a problem to tell him to use the other color.
If i switch to the 2nd Extruder in Cura the extruder is heated and its starts to print with the 2nd color, but then the extruder-head is not staying heated ( since its connected to color 1) and the filament cannot be pushed through anymore.
Most likely somebody with some skills can just give me a command or something i have to put into the starting sequence , or something like that ?
