Geeetech A30 wont connect to windows
ConnorMAU
Post by ConnorMAU »
Hello , im very new to 3d printing and am having some problems, any help is appricated
Issue one
the printer wont connect to windows 10 no matter what , ive got a fair few modelling programs and printing programs but none of them seam to pick up the printer with no errors at all or explanation ,ive browsed the forums and downloaded all the drivers i can
Easy print 3d knows the printer is there but it doesnt know any thing else
Issue two
every print ive managed to get have been terrible with the sd card , ive looked for others settings but the printer seams to pick the filament back up ones its been put on the board
Here are my setting as i assume thats my fault
Cura
settings 2.png (42.51 KiB) Viewed 5912 times
EasyPrint 3d
settings 3.png (71.82 KiB) Viewed 5912 times
settings 4.png (130.96 KiB) Viewed 5912 times
settings 5.png (150.62 KiB) Viewed 5912 times
Issue three
When i am using ultimaker cura the 3d printer continuiously beeps the turns off then will boot back up straight away once again beeping twice then repeat
Im extremly sorry about the massive wall of text and sorry if something simular has been asked
A30 Firmware version is 1.35.56
A30 serial number is1808118A30002033
a30 hardware version is 2.1-null
Pc specs
windows 10
nividia 1080ti
i7 6700k
32gb ram
Lexan
Re: Geeetech A30 wont connect to windows
Post by Lexan »
- to upgrade your firmware take easyprint
- to connect your printer i recommend slice it via cura, slic3r pe, s3d or somethink else and use pronterface
- alternative a raspberry pi with octoprint is also a nice solution to get wifi to your printer
