Printer error at final hurdle
Daza-C
Post by Daza-C »
Hi all
This isuue has just popped up and im at a loose end on what to do so any and all advice to sort this will help me loads!!
I have just got the A10 printer ( single extruder) i have assembled it ok.. well as far as the translation got me with the images and wording..
then i installed the repetier host 2_1_3 and easy print.. went through the manual on setting up and configuring the printer.. all went well and it got to the part of me printing an object.
i downloaded someone elses project and ran it through slic3r no problems and saved it to SD card.. when it came to selecting project it heated the bed up no problem, made a noise and then does nothing for heating the extruder.. i waited for a while and nothing.. a forum post advised to update the firmware which i did because no matter how many times i selected anything to print it wouldnt heat up the extruder..
i so went through the forum post to update the firmware with arduino 1.8.5 as recommended and the firmware recommended on the site A10_marlin1.1.8.zip for Geeetech A10 with GT2560V3 board
all went ok no problem.. i started to go through the process of printing from SD card again and heated the bed ok but when it comes to the extruder heating it comes up with the error (HEATING FAILED) PRINTER HALTED please reset
im stuck and frustrated so if anyone can shed light to resolve this situation i would be greatful to you
https://drive.google.com/open?id=1nAx88 ... 8WJwO9YeTS
https://drive.google.com/open?id=1voESR ... 0LxZ5NIyy1
https://drive.google.com/open?id=1pU170 ... oHPwy6CLI2
Re: Printer error at final hurdle
:mrgreen:
If you are using office clips, remove them.
Daza-C
Post by Daza-C »
Thankyou for the reply, im not sure what you mean by office clips.
Daza-C
Post by Daza-C »
WOW, how could i miss that... your such a big help thankyou so much.. that has solved everything... :lol: :twisted: :twisted:
best advice EVER!!! glad this is such a helpful forum!!!!
any real help would be greatful as its limited time under warrenty!
