Depending on filament, nozzle etc. You should change it from 1.0 to 1.1 or 1.2.
extruder extruding too slow!!!!
Re: extruder extruding too slow!!!!
Have You tried to change the extrusion multiplier for the filament?
- vykiholmes
hi
i've had same prob only extruder is fine when manually send code to extrude 1-100mm but during prints it just wasn't coming out.
My fix consisted of e step calibration & firmware update.
Could you attach the gcode file?vykiholmes wrote: Wed Feb 20, 2019 1:28 pm hi
We can use it and test it.
cheers
