Profiles for Repetier Host / Slic3r for A20M?
Share your configuration profile, please specify your printer model and the slicer software.
BR365
Post by BR365 »
I'm looking for profiles for the A20M to be used with Repetier Host and the Slic3r software.
The print of the test Dog is quite well but my own parts I tested were underextruded. So I increased extrudion to 120% and later to 150%, but it didn't help.
Or should I try a slower speed?
Is there a Config Bundle available for Slic3r?
Moritz
Tomyuan
Re: Profiles for Repetier Host / Slic3r for A20M?
Post by Tomyuan »
Maybe mine's is not perfect.
But you can have a try:
Geeetech A20M.zip
(1.76 KiB) Downloaded 2842 times
Does the extruder working temperature achieve Preset temperature?
BR365
Post by BR365 »
William wrote: Thu Apr 25, 2019 9:36 am Does the extruder working temperature achieve Preset temperature?
Hello William,
I don't have a thermometer, therefore, I didn't check this. The Dog was printed with 205°C:
This looks very good, I think.
See Discussion here: http://www.geeetech.com/forum/viewtopic ... 08&t=68468
Thanks,
Moritz
BR365
Post by BR365 »
Tomyuan wrote: Thu Apr 25, 2019 9:24 am Maybe mine's is not perfect.
Geeetech A20M.zip
This one is for ABS, isn't it?
Maybe interesting would be the E-Step value of Your setup. Maybe, my value isn't perfect. I didn't check yet.
Greetings
Moritz
Tomyuan
Post by Tomyuan »
Hi,BR365
:D
I am using the PETG for my A20M.
You can change the temp of the bed+temp of the hotend.
Then the others settings same as my PLA setting
BR365
Post by BR365 »
Tomyuan wrote: Thu Apr 25, 2019 1:42 pm Hi,BR365
:D
Thanks,
and could You tell me Your value for Esteps/mm?
Moritz
Tomyuan
Post by Tomyuan »
If you want to calibrate your estep.
Refer to this vid:
https://www.youtube.com/watch?v=X3A9Ir2SreI
My estep is 457
:D
BR365
Post by BR365 »
Tomyuan wrote: Thu Apr 25, 2019 1:57 pm If you want to calibrate your estep.
Refer to this vid:
My estep is 457
:D
Thanks, I will check.
My current value is 340, AFAIK.
BR365
Post by BR365 »
Hi Vert,
I guess, the only possible solution is to remove these disks.
E-Steps changed to 422 (Calibration done), ...
No new result depending the stringing.
