Geeetech A20M 24V in the structure
juanter
Post by juanter »
Only a few days ago I have the Geeetech A20M printer.
I have detected, after taking a spark, that there are 24V between the chassis of the fuser and the rest of the chassis of the Geeetech A20M Printer.
https://www.youtube.com/watch?v=6unUT5f ... e=youtu.be.
Also damaged the 10A fuse of the GT2560 board
Someone knows how to fix it?
Re: Geeetech A20M 24V in the structure
Hi, You can
  1. After replacing the fuse on the motherboard, check if the three lights on your motherboard are properly lit;
  2. Measure the output voltage of the power supply.
You can refer to this:
