Nozzle completely stripped, now what?
rwlroc
Post by rwlroc »
The flimsy wrench that comes with the A20M bent trying to loosen the nozzle. I used a craftsman wrench. The brass stripped. Tried vice grips. Is the next resort a new heater block? Thoughts. It is not coming out.
rwlroc
Re: Nozzle completely stripped, now what?
Post by rwlroc »
Well, using a hardened steel allen wrench, the screw holding the heating block on stripped too. The factory overtightens and as a result I need a whole new head just trying to change a freaken nozzle.
DzzD
Post by DzzD »
You must heat the nozzle (190° approx) to be sure that plastic dont block it.
Trying to unscrew a cold nozzle can result in a crushed nozzle.
Jarda3d
Post by Jarda3d »
Bras tip need to be removed hot, not cold.
Use this tool after extruder is heated
https://www.carid.com/images/knipex/gar ... 0118us.jpg
A10 Slic3r profile: here
:D Hi, for nozzle replacement,
you can try heating it up https://www.youtube.com/watch?v=aKp_QzApoEM and then unscrew it with a tool.
You can refer to the video for specific operations:
