MARLIN 1.1.9 FOR I3 prow
miguelopomelo
Post by miguelopomelo »
Hello
I am trying to load version 1.1.9 to my I3 proW, it has the GT2560A + and it does not have any type of self-leveling, I have tried to load the one from the proB, since it is the only one that I have found already configured, but when making the auto home I It gives an error, I don't know if the entire section of the self-leveling sensors can be disabled in the marlin. Currently I have loaded the firmware of geeetech 1.0.5, but my intention is to change the drivers that it has for some tmc2208, I do not know if there is any later version.
Thanks for your help
Re: MARLIN 1.1.9 FOR I3 prow
Hi,we have not used the marlin 1.1.9, nor have we tested it, so it is recommended that you use our firmware.
miguelopomelo
Hi.
The truth is that version 1.0.5 of your firmware works quite well, but i need to change the A4988 for some TMC2208 ( my wife cannot bear the noise of the printer and the truth is that I understand her ) I would have to be able to edit that firmware to change the direction of rotation of the motors and I think something else, although if you tell me that only Physically reversing the connectors on the motors would work fine, I could try it.
Hi,you can change the black and green line order as shown.
miguelopomelo
Thank you very much, I will try it as soon as the TMCs arrive
