A10M - NO FILAMENT COMING OUT HOT END - NO GLOGGING!!!
Liasonkhan
Post by Liasonkhan »
Dear fellow A10M users,
I have an issue with my A10M : No filament going out of the hot end. It's not clogged because I have cleaned it and finally changed it by a new one with the exact same issue.
I also changed the PTFE by new ones and check the connectors too. Everything seems to be alright.https://sarkariresult.onl/ Mobdro https://pnrstatus.vip/
I suspect both extruders not pushing enough the filament. I have adjusted the screws and cleaned the gears. It was working with under extrusion for a while. Now it’s not working again. I have planned to install metallic ones instead of the original plastic one.
Some help would much appreciated :)
Thanks in advance
Re: A10M - NO FILAMENT COMING OUT HOT END - NO GLOGGING!!!
Hi, You can try
1. Manually heat the nozzle to 200° and then push the consumable to see if the nozzle is discharging;
2. Check the spring tension of the feeder;
3. Check if the extruder motor is running normally. If it is not working properly, you can exchange other shaft motor wires to the extruder motor for viewing;
4. Check to see if the Teflon tube is fully inserted.
I hope this can help you.
