I have an issue with my A10M : No filament going out of the hot end. It's not clogged because I have cleaned it and finally changed it by a new one with the exact same issue.
I also changed the PTFE by new ones and check the connectors too. Everything seems to be alright.https://sarkariresult.onl/ Mobdro https://pnrstatus.vip/
I suspect both extruders not pushing enough the filament. I have adjusted the screws and cleaned the gears. It was working with under extrusion for a while. Now it’s not working again. I have planned to install metallic ones instead of the original plastic one.
Some help would much appreciated
Thanks in advance
