Mecreator 2
Re: Mecreator 2
Hi, You can check if the x-axis in the auto home touches the limit switch correctly.
Then use lcd to move the x-axis to see if it can be moved to 160.
MagicALL
Re: Mecreator 2
Post by MagicALL »
and who and why firmware use?
1- MeCreator2固件.zip
(293.54 KiB) Downloaded 5250 time
Update:new version of mecreator2
(fixed the print area not correct)
2 - MeCreator2-1.0.4.zip
(305.39 KiB) Downloaded 1211 times
3 - MeCreator2_G03 (hex)
thanks
Re: Mecreator 2
Hi, If you want to use Arduino to update the firmware, you can choose 2.
The firmware uploaded by Arduino is configuration.h.
The hex format firmware is compiled and cannot be modified.
dragonet80
Re: Mecreator 2
Post by dragonet80 »
I have an MeCreator2 wich says version 1.0.3 in "About" menu. I do not know if this is last version of firmware. I downloaded "MeCreator2-1.0.4.zip" and in Marlin_main.cpp file it says
#define VERSION_STRING "1.0.2"
So I am confused. Is it version 1.0.4 as zip file says? Is it 1.0.2 as Marlin_main.cpp says? Do I have to upgrade my 1.0.3 version?
Kaleidoscope
Re: Mecreator 2
Post by Kaleidoscope »
hoadao3493
Re: Mecreator 2
Post by hoadao3493 »
Thank you for sharing this great article. 888b hopes you will have many more articles for everyone to read.
