Problem printing fine detail.
Softfoot
Post by Softfoot »
I have a I3 Pro C and am running the latest Repetier-Host and Slic3r.
I am trying to print a replacement drive belt clamp https://www.thingiverse.com/thing:1724855 for a friends unit
but while the print quality is fine the teeth that mesh with the belt are missing!!!
Interestingly, the preview generated is also lacking the teeth - so I guess it's no surprise they dont get printed!
What am I missing?? I have tried 2 different designs and Cura doest the same.
I have the layer height set to 0.2 (but 0.1 dos the same!)
Any suggestions very welcome.
A rather desperate Dave
Re: Problem printing fine detail - help needed!
Hi, can you provide your printed picture?
If you want to see the preview, you can view it after slicing the STL.
Softfoot
Re: Problem printing fine detail.
Post by Softfoot »
The slots that hold the belt are smooth - there is no trace of the teeth that are supposed to engage with the belt.
Yes, I can see the preview - as I said in my post, it does not show the teeth either which I suppose why it is not printing.
Dave
Hi, I tried to slice it,
The preview after slicing is like this:
Softfoot
Post by Softfoot »
Interesting ... thats NOT what I get :-(
What settings are needed to get that - I am pretty well using the defaults.
It seems that you are using RH v2.1.3 and I am on v2.1.6 --- I wonder if that could be the problem ???
Interestingly in desperation I tried EasyPrint3D and that worked a treat! So that has got my friend out of the manure :-)
But I need to use BOTH extruders so I need RH.
Regards,
Dave
