[solved][Opgelost]head extruder a20t not working good
andrevanderweide
Post by andrevanderweide »
the head is not working for 1 color the other working fine i did complete clean of the head but stil no luck tempature and extruder motors working al good that is not the problem.
also with the firmware is original its the same.
greatings from the Netherlands
Last edited by andrevanderweide on Sat Apr 04, 2020 3:31 pm, edited 1 time in total.
Creality Ender 3v2
Creality S10 Pro Marlin 2.0
Re: head extruder a20t not working good
Hi, Can you provide print pictures or videos?
andrevanderweide
i did make a little testprint with change the 3 colors its with original geeetech firmware only its a magnetic bed of creality :mrgreen:
Creality Ender 3v2
andrevanderweide
i find the problem the steel balls where tight in the head i clean the head again and now its working normal with the original firmware.
And now back on vert his b483 Marlin 2 version i think is the best.
Creality Ender 3v2
Oli99959
Post by Oli99959 »
I have the same issue but I don't understand what you mean. Could you post a picture of these "steel balls" please?
andrevanderweide
there for every filament tree imbus with behind a second imbus and there behind are the steelballs
Creality Ender 3v2
Oli99959
Re: [solved][Opgelost]head extruder a20t not working good
Post by Oli99959 »
Thank you for your reply.
I understand that what you call "imbus" is what I would call hex screw / Allen screw in my country.
I tried to unscrew the 1st "imbus", but I did not manage to make it turn at all.
I used the key provided by Geeetech. It seems to fit just right in it, but when I turn it slips inside. I feel that I am damaging the "imbus".
andrevanderweide
make the head hot with hair dryer or paint burner when you have the rest removed
sometimes then the get lose
Creality Ender 3v2
