geeetech a10m retraction problems
vladiivakh
Post by vladiivakh »
Hello! I have a geeetech a10m 3d printer, and when I make a retraction test I have stringing! I tried ridiculous retration settings like retraction distance as 30 and retraction speed as 100 and get strings.The most important here is that, when I buy my 3d printer I don't get any problem! Please help me!
Re: geeetech a10m retraction problems
It is recommended that you set the parameters as shown :D .
vladiivakh
Thank you! I'm going to try!
vladiivakh
Oh! And other question. What´s the slicer that you use?
vladiivakh
Sorry! Don't work! I'm getting strings!
P.S. I use cura
The above picture is the parameter setting of repeter-host. If you are using Cura, you can download the Cura file of A10m at the link below and import it.There are detailed import steps in the downloaded file.By the way,the retraction setting of cura is shown in the figure. :D
https://www.geeetech.com/download.html?download_id=47
vladiivakh
Hi! I solved my problem. I tried simplify 3d and no stringing! The problem is simplify is paid...
