i need help with Heatbed MK2a
gastipincha
hello, i have my new 3d printer Geeetech Acrylic Prusa I3 Dual extruder. i build it, folowing the instrucctions but there is something that it is not working. the heatbed mk2a I understand that this part is Pre-Soldered before shipping. I just attached the bed directly.
The thing is that the bed Does not Heat up! when i go to Repetier ,and set the temperature of the platform, the temperature stays on 0.
Can someone help me please ? im new in this 3d printer world ...
i will attach the actual situation of my heatbed.
- image.jpg (304.07 KiB) Viewed 10682 times
zhangxueyou
Re: i need help with Heatbed MK2a
Is hotbed thermistor plugged? You can not heat the hotbed if thermistor is not plugged.
gastipincha
Yes , the hotbed thermistor is plugged
zhangxueyou
What is the LCD displaying? It would be better if you leave a picture.
And you should confirm the hot bed is connected correctly.
gastipincha
The hot bed is connected
the LCD is displaying 0/95 'c (i set 95 'C) but it stay on 0
I will leave a picture as soon as i can.
zhangxueyou
Even it can not heat, the LCD should not display "0/95". If it shows "0/0" when not heating, the hot bed thermistor is not well plugged or plugged to the wrong slot.
gastipincha
i think the problem is on the Control board GT2560... the ligth of the heatbed dosnt turn on but hte others do . should i try to touch the reset button ?
- image1 (2).JPG (71.78 KiB) Viewed 10659 times
zhangxueyou
If LCD displays "0/95" when heating and "0/0" when not heating, you should check if the hot bed thermistor is fine, because when it is not well plugged, or when somewhere of thermistor is open circuit, LCD will display like that.
gastipincha
well , i been trying to what you told me to do, but now my problem is bigguer. Now the printer does not responde, the fans are dead and the x acis y axis z axis dosnt move when i use repetier and press autohome... i dont know what to doo . ill try to check the hot bed thermistor is fine ...
tx for your time !
tx for your time !
gastipincha
i ve been talkingwith some guys from the support and we find out that there was a problem with one of the fuse, i need to remplace it now and see if the printer runs again. but i dont think that will solvethe heatbed problem , there is something brong in the controlboard , the part of the heatbed i guess
