Multi Color Printing Problem
rmrodrigues
Post by rmrodrigues »
Hi There,
I'm trying to print a key holder example made by me but the second extruder is printing out of the correct location.
Please see the attached photo.
When I use Slic3r the extruder print at same time and side by side. This gcode was generated with CURA and the result is above.
Any suggestion?
Best,
RMRodrigues.
Mark
Re: Multi Color Printing Problem
Post by Mark »
the photo is broken...
rmrodrigues
Here is it:
Thanks Mark.
Mark
Post by Mark »
oh I see you use cura, sorry I haven't used it before...
rmrodrigues
Hi Mark,
I've used CURA as an alternative to Slic3r.
There is a guide to do that on Slic3r?
Thanks.
rmrodrigues
Mark I think that my problem is due to a bad offset. What you think about that?
Mark
Post by Mark »
I think you can refer to this link to check the settings:
http://www.geeetech.com/wiki/index.php/ ... _extruders
