Arduino Fio
profgino
Arduino Fio
Post by profgino »
Somebody help me? I dont get conect my Arduino Fio inSupply 5V (USB)
techsupport
Re: Arduino Fio
Post by techsupport »
Hi friend;
The USB cable connected to the Arduino Fio is just for power supply .Like Arduino Pro Mini, You need a FTDI breakout board for Fio to upload sketch.
http://www.geeetech.com/ftdi-basic-brea ... p-417.html
Regards,
Techsupport
Email: forum@geeetech.com
profgino
Re: Arduino Fio
Post by profgino »
Hi. When I connect my FIO using USB, he doesn't have tension of 3,3 V. The Regulator non ofrnece this tension for the circuit.
Is the mistake in the regulator?
techsupport
Re: Arduino Fio
Sorry for the mistake, the mini usb connector is only for battery charging,so the Arduino Fio can be powered with FTDI breakout board on the six pin headers,
or with regulated 3.3V supply on 3V3 pin or a Lithum polymer battery on BAT pins
profgino
Re: Arduino Fio
Post by profgino »
I Have another FIO (sparkfun) and when I tie the mini USB the led CHG (charger) is on. In your FIO. the led is extinguished.
I measured with my mutímetro and in the pin of 3,3 V doesn't have any voltage.
Leaning that should be some problem in the connections or in the regulator of 5 V for 3,3 V.
Does he/she have as I solve that?
techsupport
Re: Arduino Fio
Hi friend,
You can try to test it with 3.3 voltage from UNO or your another Fio on 3V3 pin using jumper wires.
profgino
Re: Arduino Fio
Post by profgino »
Do you have the component code of regulator voltage? I will get the datasheet for studing
techsupport
Re: Arduino Fio
LP2985AIM5-3.3 for 3.3V regulator, MAX1555 for battery charge adapter
alison3492
Re: Arduino Fio
Post by alison3492 »
this is very interesting
alison
