Arduino Fio
Arduino Fio
Somebody help me? I dont get conect my Arduino Fio inSupply 5V (USB)
- techsupport
- Site Admin
Re: Arduino Fio
Hi friend;
The USB cable connected to the Arduino Fio is just for power supply .Like Arduino Pro Mini, You need a FTDI breakout board for Fio to upload sketch.
http://www.geeetech.com/ftdi-basic-brea ... p-417.html
Regards,
Techsupport
Regards,
Techsupport
Email: forum@geeetech.com
Re: Arduino Fio
Hi. When I connect my FIO using USB, he doesn't have tension of 3,3 V. The Regulator non ofrnece this tension for the circuit.
Is the mistake in the regulator?
- techsupport
- Site Admin
Re: Arduino Fio
Sorry for the mistake, the mini usb connector is only for battery charging,so the Arduino Fio can be powered with FTDI breakout board on the six pin headers,The USB cable connected to the Arduino Fio is just for power supply
or with regulated 3.3V supply on 3V3 pin or a Lithum polymer battery on BAT pins
Re: Arduino Fio
I Have another FIO (sparkfun) and when I tie the mini USB the led CHG (charger) is on. In your FIO. the led is extinguished.
I measured with my mutímetro and in the pin of 3,3 V doesn't have any voltage.
Leaning that should be some problem in the connections or in the regulator of 5 V for 3,3 V.
Does he/she have as I solve that?
- techsupport
- Site Admin
Re: Arduino Fio
Hi friend,
You can try to test it with 3.3 voltage from UNO or your another Fio on 3V3 pin using jumper wires.
Re: Arduino Fio
Do you have the component code of regulator voltage? I will get the datasheet for studing
- techsupport
- Site Admin
Re: Arduino Fio
LP2985AIM5-3.3 for 3.3V regulator, MAX1555 for battery charge adapter
alison3492
