endstop status check
Toy
Post by Toy »
If you've met some troubles about homing, then usually it's the problem of endstop.
Note that, you need to home the printer after you start it or you'll get wierd behaviors such as crash to the bed, move only in one direction, etc.
For G2 or G2S, come here:
http://www.geeetech.com/forum/viewtopic ... 13&t=17042
For other printers,
Make sure the wire is corrected to pin1 and pin2
it should be connected to min socket.
If you find a endstop doesn't work, you can plug it to other axis, see if the endstop is defective.
You can also use M119 code to check if the endstop works.
Homing the printer first, and use M119 to check the endstop status. If the printer can not home itself, you can manually trigger the endstop one by one.
Then you'll get
18:10:11.392 : x_min: TRIGGERED
18:10:11.392 : y_min: TRIGGERED
18:10:11.392 : z_min: TRIGGERED
Then move the extruder from the endstop, send M119, and you'll get
18:16:55.066 : x_min: open
18:16:55.066 : y_min: open
18:16:55.066 : z_min: open
