Bed Offset Correction
hwurzburg
Post by hwurzburg »
I am trying to center prints on the bed...and using BLTouch, which homes in the center...there is a 13mm X offset to all prints...I am using Cura
I have tried M206 X13 to shift the bed position, but while the printer accepts it, it does not seem to actually work....its not reported in M503
how do I center prints? (SLIC3R has an offset in printer profile, Cura does not)...
EDIT: found the Cura setting....
Jarda3d
Re: Bed Offset Correction
Post by Jarda3d »
There are some hard coded software limits to bed size in the printer?
See what it does on bigger print
And settings
and what it si sliced
A10 Slic3r profile: here
Jarda3d
Post by Jarda3d »
Bad news. Hardcoded nice 220, but real printable size is X210 x Y215. Look at offset 10x5mm.
Why not to use real printable size at least 230x230mm? There are tolerances 5mm (which is really needed, machinery precision of complex object is not good - if you did not see it, you are lucky or blind).
