Repetier-Host setting on ABS print
animetown9
Post by animetown9 »
Does anyone here have a good setting for Repetier-Host ABS printing with
Acrylic Geeetech I3 pro and Sanguinololu 1.3a.
zhangxueyou
Re: Repetier-Host setting on ABS print
Post by zhangxueyou »
Please tell me the filament diameter and nozzle diameter.
animetown9
Filament 1.75 , nozzle 0.3mm
ABS filament.
zhangxueyou
slicer settings(1.75-0.3).zip
(715.7 KiB) Downloaded 1025 times
johnz
Post by johnz »
How about setting for 1.75 and 0.4 ABS?? Thanks
you can use the settings above too, just need to change the diameter of the nozlle to 0.4mm.
Also you can refer to the link here to use the repetier host:
http://www.repetier.com/#documantation
Derekchong
Post by Derekchong »
I followed these setting but the print out is horrible. Any good advise?
Abs hollow cube
Abs hollow cube
