Prints not center on heated bed and how to Sd card printing
3d_daw
Post by 3d_daw »
After so many hours spending calibration and many problem encountered I finally able to print ... I have a Delta Restock Mini G2s dual extruder bought last August and haven't use the printer...now, I've got another issue...
1. How do I center the prints on my G2s ... As it appear the print is more towards near the LCD panel
2. I was looking at tutorial how to use or printing using SD card...but not found any topic here and no instructions found.can you provide any step/ guides
Thanks for the help in advance, please Help.
Re: Prints not center on heated bed and how to Sd card print
If you use repetier 1.5.6, you can slice the object with slic3r, and generate the .gcode file for SD card printing here:
"How do I center the prints on my G2s ... "
and how do you set your printer setttings?
3d_daw
Post by 3d_daw »
Hi Mark,
Thanks for the help... I followed your instructions and settings ... it's still off by at least 10mm ...
Not sure we're to adjust these... .I marked the center (+) and the center for printing was (dot) ...anyway I'm good with this rather than before 20mm but it would be nice if it was centered...
I will check the Sd card printing and will let you know.. Thanks again
wait, let me see, and have you set the settings here for dual extruders?
you can refer to the link here to set them:
http://www.geeetech.com/forum/viewtopic ... 13&t=17064
3d_daw
Post by 3d_daw »
It finally work...hurray!!! It was centered :D
I guess you have to update the "wiki instruction " with these "Y off set " settings need to adjust when you have G2s ... So every user /buyer won't have difficulty finding information such like these.
Again, thank you for the help!
Will update it later sometime, thanks for yor advice!
