I want to start looking at 3D printing, this company kits seems a good buy in for learning from the ground up.
It does say it needs a two twenty volt onnection, does that mean to connect these to a uk mains plug socket I would need to go via a power step down converter box to lower the normal uk two forty volts down to two twenty or even one ten volts?
						Do I need a power step down converter in uk
Re: Do I need a power step down converter in uk
The UK is 110v, is it right?
For our PSU, it has a mode to switch the 110V or 220V.Don't worry about it.
