A10M sudden layer shift ?
SackofFluor
Post by SackofFluor »
Sudden frame shift.
Hey guys, i was printing some bigger piece with the "extra-fine" settings. After around 16h of print time the x-axis ( is that the one that moves "back and forth with the buildplate?), obviously had a problem, resulting in the layers from one leyer to the next be moved by 4-5mm, after that shift occured the printer continued printing without any hassle.
Any idea how to fix that ?
Re: A10M sudden layer shift ?
@SackofFluor
Hi!
How is it going on?Did vert's suggest work or not?
SackofFluor
Hey William,
Sorry i was busy printing. Actually i just decided that i will run with it until it shows up again... and so far it hasnt happend again.
Sincerely
Sack
S.Bartfast
Post by S.Bartfast »
vert wrote: Sun Mar 10, 2019 3:30 pmthe stock firmware uses 80.3 and 80.8 steps on xy any not whole number is subject to the rounding error where over time of the print you get +-1 step resulting in holes and bumps that could give a shift.
Could you explain this a little more?
I have a simular issue to the OP however I am getting constant shifts on both my X and Y axis and have tried everything else you mention above but don't understand what you are saying here.
Thanks.
Also, what should I do if I do have the a4988 (which I suspect I might):
M10A board.jpg (447.95 KiB) Viewed 6539 times
Here an photo of my latest print:
Hi, regarding the adjustment of the belt,
You can refer to this:
How to adjust the x-axis belt: https://www.youtube.com/watch?v=QmrT1sPhvf8
How to adjust the y-axis belt: https://www.youtube.com/watch?v=ZoOaT5fkgfg
Regarding the speed of the print, you can refer to the range of 30-60mm/s;
If you need to adjust the driver board voltage, you can refer to this to make adjustments.
A4988 测量位置.jpg (192.77 KiB) Viewed 6535 times
Reference range 0.8-1.2V.
S.Bartfast
William wrote: Sun Sep 15, 2019 1:39 pm Hi, regarding the adjustment of the belt,
Yes, I am aware of this. What I am wanting to know is what is meant by:
And also how does one check if they have a "a4988" driver and what to do if I do have one.
Thanks.
Hi, Refers to the step value on each axis,
You can refer to this x/y algorithm.
http://www.geeetech.com/forum/viewtopic ... 66&t=68941
