Geeetech A10
Marlin 1.1.8
I purchased a spool of white filament from eBay and had to set the flowrate to 500% for it to properly print.  Is this normal?
UPDATE:
It turned out the spool was partially deteriorated.  A simple test is to bend a bit of filament.  If it bends it is okay, but if it is brittle and breaks in half it is not suitable for use.
													White PLA problem (solved, sort of)
