Print area not identical between Cura and printer
heiberbn
Post by heiberbn »
i need help with my Geeetech A10 and the Software Ultimaker Cura.
The print area in the Cura view is not same like the Printer plate.
In the attachments you will see the differentes.
It will be cut off on the right side.
My Cura version is 4.0.0
What can I do against it?
Thanks a lot.
Bernd
Cura settings
Cura settings
in Cura
in Cura
on the plate
on the plate
Re: Print area not identical between Cura and printer
Oh ,I am afraid you need to change the print volume. The A10 print volume is in the range of 220*220*260.
