Is this something loose or y axis step is off. Or something else? How do I fix?
The dog came out perfect. Everything else drifts forward. Great bed adhesion.
Print drifts
Print drifts
- IMG_20190731_193208.jpg (391.89 KiB) Viewed 2619 times
Re: Print drifts
Hi, Hi, You can do the following checks
1. Check the tightness of each shaft and make appropriate adjustments.
For details, please refer to this:
https://www.youtube.com/watch?v=QmrT1sPhvf8
https://www.youtube.com/watch?v=ZoOaT5fkgfg
2. Check whether the bearing and the pulley are issued (the card can be lubricated for lubrication);
3. Appropriately reduce the printing speed, the reference range is 30-60mm / s.
I hope this can help you.
