LCD screen Blank
Sgrondi
LCD screen Blank
Post by Sgrondi »
Not sure if there is a bad fuse (location unknown) of if the A10 printer I just bought has the wrong Power supply or the cpu is bad Says GT2560 ver 3.1 but does not look like the one on parts page . only 1/2 of power plug has wires and only one feed from power supply 2 wires not 4. No 5v light any help in fixing this (new?) a10 I received this printer with the micro switch on print head arm broken and it has been replaced. both power lights are lit.
Re: LCD screen Blank
Hi, Can you provide specific pictures?
When the printer is turned on normally, the three lights on the motherboard are normally on.
you can refer to this:
V3 三灯亮起的位置.jpg (1.51 MiB) Viewed 3530 times
Sgrondi
Post by Sgrondi »
Got it (smile)I had replaced the Micro switch (stop Switch) with generic switch. no LED on Switch. Removed 5 volt power wire from switch plug, was shorting out power. My printer is up and running and has printed a test Dog came out great. Where do I get the factory stop switch's looking for 2 506l one is working LED out the other works but not factory also no LED Thank you.
Hi, Can you provide specific videos or pictures?
Sgrondi
Post by Sgrondi »
First pics of stop switch temp fix? last 2 are of old stop switch I'm looking for 2 of.
