Geeetech A30 Cura 4 Print Head Settings
projectquad
Post by projectquad »
Hi everyone
Just received my Geeetech A30 printer, loaded Cura 4 and used the creality cr10 profile, the printed bench boat was perfect. Change the printer to the default geeetech a30 cura 4 ships with and tried another print, it was terrible, could not compare. So i noted the creality cr10 profile was far superior in print quality.
After some thought, before i try larger prints please could you help me confirm the print head settings are correct? See attached image.
Cura 4 Creality Cr10 profile used on Geeetech A30
Re: Geeetech A30 Cura 4 Print Head Settings
Hi, Your printhead settings should be changed.
If you are using cura4.4, you can find the A30 printer.
projectquad
Hi William
I tested the A30 profile in Cura 4 and the print was terrible, using the creality cr10 profiles my prints were perfect. however this was tested in a 150mm x 150mm x 150mm model, i am afraid to use the same creality cr10 profile print head settings for much larger prints. Please could you help me with configuring the Cura 4 creality cr10 profile print head settings to work as it should with the A30?
Hi, I find this. and you can refer to this:https://www.youtube.com/watch?v=yY2QvpWOXYE
Diane90
Post by Diane90 »
William wrote: Wed Dec 04, 2019 9:11 am Hi, I find this. and you can refer to this:https://www.youtube.com/watch?v=yY2QvpWOXYE
Thank you for posting something like this
