flash gone wrong
cpt.vollboon
flash gone wrong
Post by cpt.vollboon »
Hey guys,
i think i killed my geetech a10t Motherboard
while flashing via cura my pc got a Bluescreen and now the printerdisplay shows only [][][][][][][][][]
my pc shows the printer as COMport4 as it should be, but cura says that there is no connection
on the store I cant find a Motherboard gt2560v4 anybody has an idea?
Re: flash gone wrong
:D Hi,you can refer to this:viewtopic.php?f=20&t=69705
I hope this can help you.
cpt.vollboon
flashing with cura doesn´t work anymore, it says there is no Connection to the printer
with firmwareupgradetool AVR says invalid file format
what am i doing wrong?
@vert how do I know at what moment i have to press reset?
and how can i flash with VScode?
cpt.vollboon
thank you, but I already saw this Video
my Problem was, that in the path (where the new Firmware was) had a space in a foldername :oops:
so I changed the foldername and now AVRDude starts, but now AVRDude gets a timeout :/
i turn on the Printer, wait about a Minute, then start the firmwareupgradetool, select the correct COMport and the .hex with the Bootloader ( I tried the .hex without Bootloader also) press and hold the resetbutton on the Display and hit Upgrade from local while releasing the button.
now this ERROR appears
cpt.vollboon
ups, didnt knew that :oops:
which board do i need to order for the A10T?
because the V4 isn´t in the geeetech-store available
:D Hi, If your motherboard chip is damaged,
You can contact your sales description,
Or provide your purchase address,
Country, order number and email.
I hope this helps you.
habefugyjy
Post by habefugyjy »
Gree tech A 10 series is generally associated with the 3D printer technology and this post is about flash that gone wrong. The post is related to the killing of mother board and Australian Writings is assisted the various kind of matters with the taking of the different ideas.
