Marlin 1.1.9 firmware upgrade
DzzD
Post by DzzD »
I am planning to upgrade my A20m to Marlin 1.1.9, I am wondering if anyone already done this and can give some feeback like is there any quality improvment on print ?
Re: Marlin 1.1.9 firmware upgrade
Hi, you can view the 2.0 version of vert
DzzD
Post by DzzD »
Yes, I've tested it :), compiled and running on my A20m, but didn't see any quality improvement.
I also have tried a junction deviation test print's (see picture), but I cant see any difference, why ?
Hi, you can try to check if the z-bar is shaking and tighten it.
Check the bearing or the pulley for card issuance, and lubricate it with lubrication.
DzzD
Post by DzzD »
junction deviation gets better the lower the value the default in marlin 2 is 0.013 you tested from bad to worse not better.
Haa ok ! I understand, So I will try another range.
theju
Post by theju »
DzzD wrote: Mon Nov 04, 2019 7:46 pm Yes, I've tested it :), compiled and running on my A20m, but didn't see any quality improvement.
Hi DzzD, can you share your configuration.h ?
Thx
Ju
DzzD
Post by DzzD »
Unfortunatly the forum doesn't let me share other files than ".gif/.jpg/..." so I try to inline it below
Take care as I use TMC2208 for X,Y,Z E0 and E1
DzzD
Post by DzzD »
oops, done
(accustomed to some forums that block zip files)
config.zip
(30.27 KiB) Downloaded 556 times
theju
Post by theju »
DzzD wrote: Sun Nov 17, 2019 7:08 am oops, done
Thanks !
