Marlin 1.1.9 firmware upgrade
I am planning to upgrade my A20m to Marlin 1.1.9, I am wondering if anyone already done this and can give some feeback like is there any quality improvment on print ?
Re: Marlin 1.1.9 firmware upgrade
Hi, you can view the 2.0 version of vert
Yes, I've tested it
, compiled and running on my A20m, but didn't see any quality improvement.
I also have tried a junction deviation test print's (see picture), but I cant see any difference, why ?
- JD.jpg (95.8 KiB) Viewed 14270 times
Hi, you can try to check if the z-bar is shaking and tighten it.
Check the bearing or the pulley for card issuance, and lubricate it with lubrication.
Haa ok ! I understand, So I will try another range.junction deviation gets better the lower the value the default in marlin 2 is 0.013 you tested from bad to worse not better.
Hi DzzD, can you share your configuration.h ?DzzD wrote: Mon Nov 04, 2019 7:46 pm Yes, I've tested it, compiled and running on my A20m, but didn't see any quality improvement.
Thx
Ju
Unfortunatly the forum doesn't let me share other files than ".gif/.jpg/..." so I try to inline it belowHi DzzD, can you share your configuration.h ?
Take care as I use TMC2208 for X,Y,Z E0 and E1
oops, done
(accustomed to some forums that block zip files)
- config.zip
- (30.27 KiB) Downloaded 555 times
Thanks !
