Geeetech A30M profile setting for Simplify3D and Repetier-Host
Ahrovan
Re: Geeetech A30M profile setting for Simplify3D and Repetier-Host
Post by Ahrovan »
Please guide more :cry: :idea:
:D Hi, If you import a model, it is monochrome by default.
You can slice the model and import it into the color mixer for color mixing.
If you want to print mixed colors, you can refer to the method in the video to import the model
Different parts of the
Then select different parts and choose different extruders to set up,
Check the color mixing ratio on the screen. If it is 100: 0, it will also affect the printer output.
Ahrovan
Post by Ahrovan »
The mixer worked somewhat. Most I needs to use in a single print, two colors individually In different parts, not in a mix!
please check our request. We cannot print models 1 (Extruder_1 selected) and 2(Extroder_2 selected). The program is configured with the settings stated in the video.
- Our output is one color. Or the second color is not printed at all.
- Our Extruder_1 works well. Our Extroder_2 alone works well. No hardware problem.
- Our problem is how Extruder_1 and Extruder_2 work together.
- We know that it takes some time for the filament to change.
:idea: :idea: :idea:
:D Hi, thanks for your feedback,
We will discuss
and give you feedback.
Ahrovan
Post by Ahrovan »
Thanks, I'm waiting for your reply :geek:
Ahrovan
Post by Ahrovan »
Our try (today), please check
3DAngel
Post by 3DAngel »
uncheck : printer has mixing extruder
but you may need to play retraction and purge tower size
i did not try. you will need to test
2extrudr printing.png (510.54 KiB) Viewed 10016 times
Ahrovan
Post by Ahrovan »
Our subject needs technical check. The problem is not solved
hello,
Printing multiple files at once (repetier-host)
Set multiple print heads in settings
Set different files to different extruders
Ahrovan
Post by Ahrovan »
Hi, please send us this model for test
