New A20M Model ?
psxsnake
Re: New A20M Model ?
Post by psxsnake »
theju wrote: Thu Nov 07, 2019 3:15 pm
theju wrote: Thu Nov 07, 2019 3:37 am
psxsnake wrote: Wed Nov 06, 2019 4:34 am I have same model variation.
Where you connect bltouch?
You have the 5 pins at the top of the small board, just under the big connector
Ju
Here the photo much easier to understand.
Does anybody know what is the 3 poles connector under ?
Ju
perfect thanks... the servo pin is 27?
Hardl00k69
Post by Hardl00k69 »
i have a different one kind of connexion on my A20M printer head.
Can anyone tell me how to connect 3D-Touch on this head?
Thanks,
H.
Ysorc
Post by Ysorc »
Same model same question, how to plug the 3Dtouch ?
wchuebner
Post by wchuebner »
Hallo,
upper are grounds ...
Wi
cryoglobe
Post by cryoglobe »
Hello
I have my A20M since a week now ... and only did two print :)
I bought the 3dTouch ... but when looking the way to do on my new version ( V4 ) of the A20M ... and all the issues ( failure ) I see about it
I just wonder if I should not return it , and buy the original BLTouch ...
What do you think ?
Good idea ? useless ? bad idea ? ( and why )
cryoglobe
Post by cryoglobe »
Ysorc wrote: Fri Jan 31, 2020 1:29 am Same model same question, how to plug the 3Dtouch ?
As seen on a video ( from Geetech )
brown -
red - black
orange - white
Kashban
My A20t bought in Spring has this too
Post by Kashban »
They changed the hotend slide, appearently.
Instead of flexing off the nose you can also replace the endstop holder with a modified one which places the endstop switch further left.
I use the one included here: https://www.thingiverse.com/thing:4257275.
cryoglobe
Post by cryoglobe »
Hello
Could someone provide me the values of the setting as it is "out-of-the-box" for the A20M V4 ?
Especially the one in menu "Control / Motion"
- Velocity
- Acceleration
- Jerk
- Estep
Thanks a lot
for the story summary : ( see my point about estep below )
I tested my A20M out of the box , with correct prints
I installed my 3dtouch , following the Geeetech explanations ( video )
To get sticking prints to the plate .. I had to fine tune the z offset ( as documented and explain in lots of places )
I did it with the
application "pronterface" (https://www.pronterface.com/)
following this video ( https://youtu.be/y_1Kg45APko
( I did it a second time , as it was a little bit too low / touching the bed ... )
The next issue was that all my prints ( even the gcode already tested ) were really under extruded :(
I did the estep calibration ... I had to change the value from 395 to 931.6 ( yes ... that much
to get rid of the under extrusion issue.
Emily777
Hello everyone
Post by Emily777 »
Hello guys, thanks for your photos how to connect bltouse, it helped me
Btw
I got something cool for you , if you are student
Grades are very important for students, but many students do not have so much energy, so do I, to complete every learning task, especially those about programming in languages such as Python. EssayWritingService is an institution whose purpose is to complete different problems of classmates, especially those who have accumulated many years of experience in cs writing https://write-essay-for-me.com/write-essays-for-money . Because our company employs a lot of writers in this area, we can complete your assignments within the relatively urgent deadline.
