My slicer settings
zhangxueyou
My slicer settings
Post by zhangxueyou »
I use Geeetech Prusa i3B, with 1.75mm filament and 0.3mm diameter nozzle. Slicer software is Slic3r. Attachment is my slicer settings, I got good print with these settings, you can try.
Actually, anyone who uses different kinds of printer, or the same printer with different filament diameter or nozzle diameter, can also refer to this setting. But you have to change some parameters in slic3r, including "filament diameter", "nozzle diameter", "first layer height"(it is as same as nozzle diameter), "other layers height"(I suggest lower than first layer for 0.05-0.1mm).
slicer settings(1.75-0.3).zip
(637.06 KiB) Downloaded 3689 times
How to access slicer setting and slice:
Open Repetier-Host, click "configuration" under "Slicer" tab:
Save change after you change every group of parameters.
save parameters.png (22 KiB) Viewed 74975 times
Click "slice with slic3r" to generate g-code:
slice with slic3r.png (15.88 KiB) Viewed 74975 times
You can save the g-code in SD card to print off-line:
save gcode.png (21.03 KiB) Viewed 74975 times
zhangxueyou
Re: My slicer settings
You can also load the configuration file too.
slicer config.zip
(1.27 KiB) Downloaded 3546 times
Open slic3r in Repetier Host:
import slicer setting 1.png (46.16 KiB) Viewed 75563 times
import slicer setting 2.png (52.58 KiB) Viewed 75563 times
import slicer setting 3.png (87.36 KiB) Viewed 75563 times
ingsergio
Post by ingsergio »
Greetings.
Look already sent to print out sero no filament 1.75 abs. Will speed stepper motor extruder?
zhangxueyou
ingsergio wrote:Greetings.
Sorry, I don't get your point.
ingsergio
Post by ingsergio »
Saludos zhangxueyou.
Ya estoy imprimiendo. Lo unico es que sale como remontada la figura. A que velocidad maneja el motor del extrusor?
zhangxueyou
ingsergio wrote:Saludos zhangxueyou.
La velocidad de extrusión es 95 mm / s. Se ha establecido en el firmware.
Si desea reducir la velocidad de impresión, Puede girar el saber en la pantalla LCD. Como se puede ver en la tercera línea de la pantalla LCD, "FR 100%" is default printing speed.
Traduzco del Inglés al Español en Google traducir, espero obtendrá mi punto.
ingsergio
Post by ingsergio »
Greetings.
I now have problems with the 0.3mm nozzle. He was making a solid and suddenly stopped distilling abs. (I was stoppered) disassemble the clean at all (nozzle and part where it passes the filament). Start printing again and still covered. I can do?
zhangxueyou
Cuál es la temperatura al imprimir? Cuándo parar?
ingsergio
Post by ingsergio »
When this printing varies between 240 and 221.
zhangxueyou
ingsergio wrote:When this printing varies between 240 and 221.
¿Puede imprimir con la tarjeta SD?
