Printer stops randomly
Re: Printer stops randomly
I have the A4988 stepper drives they are plug correct. I have tighten the belt, but the problem keeps. I noticed that the problem is only on X axis. Why this starts after a couple of layers and doesn't start from the beginning of the print? What other possibilities exist ?
Let's check if it's g-code issue. Please try to print with the attachment. Please raise the temperature of extruder and hot bed properly before printing.
I printed the object, the result was satisfying. So the problem is generated from gcode ?
- 11423847_970671716298605_326308983_n.jpg (74.39 KiB) Viewed 10116 times
Let's spend more time on printing one more thing to check if it is really slicer issue, please print with the attachement. Please heat up the extruder and nozzle in advance.
Attachment is extruder holder, you'd better print in ABS if you have ABS, because the holder printed in ABS is better, you can replace it in case of the older one is broken.
I tried to print the holder, you can see the result in the photo below. I printed with PLA because i haven't ABS, the extruder temperature was 200 C and the bed at 60 C. The problem keeps on ...
- sample.jpg (155.08 KiB) Viewed 10105 times
Is there any error displayed on LCD when it stops printing?
No there are no errors, the only things that lcd displays are the temperatures and the X Y Z coordinates. I usually kill the print because is a waste of material after problem appears
Please try to print again, see if it stops at the same place. If it stops at the same place, I think it is gcode issue, maybe it was not completely copied to your SD card.
The printer doesn't stop, i kill the print because is a waste of material, and i print online with repetier not from sd card
Please try to print with SD card, maybe it is Repetier's issue.
