Y- Axis Failing
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
I got the error while trying to upload the firmware>
I loaded the .ino file into the software and clicked upload. (I think there was a total of 73 files that loaded in the Arudiono for the upload
zhangxueyou
Re: Y- Axis Failing
Post by zhangxueyou »
No, drag all the files into Arduino.
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
All of the files are loaded into audrinio, 73 total
zhangxueyou
Re: Y- Axis Failing
Still displaying error? What version of Arduino are you using?
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
1.6.4
zhangxueyou
Re: Y- Axis Failing
Higher version doesn't have good compatibility, you can try to upload with Arduino1.0.1:
http://arduino.googlecode.com/files/ard ... indows.zip
jfsgi
Re: Y- Axis Failing
Post by jfsgi »
Loading via the lower version seemed to work,
I also have a problem with the slicer
I attached a photo of the issue
Please advise
6-15-2015 8-18-13 PM.png (39.52 KiB) Viewed 11026 times
zhangxueyou
Re: Y- Axis Failing
You can refer to this page to set your printer in Repetier first:
http://www.geeetech.com/forum/viewtopic ... 21&t=16512
