Heated bed not centered
mogey336
Post by mogey336 »
I'm new in 3d printing i have Geeetech Prusa I3X when i'm printing the shapes are not centered in my heated bed.
I need the slicer configuration please
Mark
Re: Heated bed not centered
Post by Mark »
Hi, Have you set the right settings?
mogey336
Post by mogey336 »
It's my default setting the heated bed not centered.
I have another problem starts today my heated bed takes almost 1 hour to reach 110 C
When i start printing X motor starts clicking at layer 20 and shifts
any suggestion?
Mark
Post by Mark »
" have another problem starts today my heated bed takes almost 1 hour to reach 110 C
When i start printing X motor starts clicking at layer 20 and shifts"
Have you checked the wires of the hotbed? It could be a bad contact.
And the X motor, whats the speed you use ? maybe is too fast that caused it. and check the belt loose or not.
mogey336
Post by mogey336 »
this is my configuration settings
The printing not in the center too
slicer setting.JPG (34.38 KiB) Viewed 19152 times
printer settings.JPG (51.14 KiB) Viewed 19152 times
Mark
Post by Mark »
Does the nozzle in the lower left of your bed after homing?
If not, you can adjust the two settings "BED Left" " BED Front" to see if it works.
mogey336
Post by mogey336 »
My homing position is lower left
mogey336
Post by mogey336 »
basecircle
Post by basecircle »
Mark you sent me the info as to setting home pos.I put it all in and when I hit home.It will go not to center but left corner.Do I manually push the axis to where I want home?If so how can I zero it.??? I have the pro 3 b printer.I do not know what i am missing. Help once more. Basecircle
mogey336
Post by mogey336 »
I have the same problem with my printer Geeetech Prusa I3X
Basecircle
