Heated bed not centered
I'm new in 3d printing i have Geeetech Prusa I3X when i'm printing the shapes are not centered in my heated bed.
I need the slicer configuration please
Re: Heated bed not centered
Hi, Have you set the right settings?
- QQ截图20150901162455.jpg (185.24 KiB) Viewed 19187 times
- QQ截图20150901162333.jpg (145.34 KiB) Viewed 19187 times
It's my default setting the heated bed not centered.
I have another problem starts today my heated bed takes almost 1 hour to reach 110 C
When i start printing X motor starts clicking at layer 20 and shifts
any suggestion?
any suggestion?
" have another problem starts today my heated bed takes almost 1 hour to reach 110 C
When i start printing X motor starts clicking at layer 20 and shifts"
Have you checked the wires of the hotbed? It could be a bad contact.
And the X motor, whats the speed you use ? maybe is too fast that caused it. and check the belt loose or not.
this is my configuration settings
The printing not in the center too
- slicer setting.JPG (34.38 KiB) Viewed 19151 times
- printer settings.JPG (51.14 KiB) Viewed 19151 times
Does the nozzle in the lower left of your bed after homing?
If not, you can adjust the two settings "BED Left" " BED Front" to see if it works.
My homing position is lower left
basecircle
Mark you sent me the info as to setting home pos.I put it all in and when I hit home.It will go not to center but left corner.Do I manually push the axis to where I want home?If so how can I zero it.??? I have the pro 3 b printer.I do not know what i am missing. Help once more. Basecircle
I have the same problem with my printer Geeetech Prusa I3X
Basecircle
Basecircle
