GT2560 Only work with USB plugged in
FrancYescO
Post by FrancYescO »
i recently bought a i3 Pro W but from the first run the LCD does not turn on, only the fans start spinning and a green led turn on on the board, the only way to get it working (and to get the printer working) is to connect the USB power (to a PC or a simply USB charger)
here a video of the issue: https://www.youtube.com/watch?v=___bmnzfczk
someone have a tip for fix the issue (i assume is something broken on the motherboard) and get the printer working standalone?
Re: GT2560 Only work with USB plugged in
You should use multimeter test the voltage of mainboard in here:
FrancYescO
[quote=William post_id=81340 time=1509961423 user_id=51382]
[/quote]
Just tested, witouth USB power supply voltage here is just 1.65v
where is the issue?
It seems not enough power supply for the mainboard.You should test the voltage in power supply(normal is 12V) :
FrancYescO
[quote=William post_id=81346 time=1510019336 user_id=51382]
[/quote]
Voltage on both connector is 12.20v i assume is okay
It seems you need a new mainboard, contact related after-sale for help.
