i recently bought a i3 Pro W but from the first run the LCD does not turn on, only the fans start spinning and a green led turn on on the board, the only way to get it working (and to get the printer working) is to connect the USB power (to a PC or a simply USB charger)
here a video of the issue: https://www.youtube.com/watch?v=___bmnzfczk
someone have a tip for fix the issue (i assume is something broken on the motherboard) and get the printer working standalone?
GT2560 Only work with USB plugged in
Re: GT2560 Only work with USB plugged in
You should use multimeter test the voltage of mainboard in here:
- voltage.png (1.64 MiB) Viewed 9440 times
- FrancYescO
[quote=William post_id=81340 time=1509961423 user_id=51382]
[/quote]
Just tested, witouth USB power supply voltage here is just 1.65v
where is the issue?
[/quote]
where is the issue?
It seems not enough power supply for the mainboard.You should test the voltage in power supply(normal is 12V) :
- powersupply.png (745.72 KiB) Viewed 9425 times
- FrancYescO
[quote=William post_id=81346 time=1510019336 user_id=51382]
[/quote]
Voltage on both connector is 12.20v i assume is okay
[/quote]
It seems you need a new mainboard, contact related after-sale for help.
