temperature problem when printing
Rush68
Post by Rush68 »
Hello everyone, I have a problem when I print.
I bought a Delta Rostock mini G2s pro, it starts printing very well and I already printed several pieces, but now it gives me an error of maximum temperature reached at a certain moment of the printing, which could be, I use the program repetier-host v2 .1.3
Re: temperature problem when printing
Post by _kaktus_ »
Hello.
Have you tried to lower the temperature by e.g. 5°C?
Repetier Host draws graphs for temperature, you can analyze what happens over time.
Rush68
Post by Rush68 »
ok, thanks, I'll try
Rush68
Post by Rush68 »
decreased 8 degrees centigrade and I still have the same problem
Post by _kaktus_ »
Hi.
Have you seen the temperature chart in RepetierHost?
Can you show the screen :?:
Rush68
Post by Rush68 »
hi here is the screenshot of the problem
problema temperatura.jpg (278.38 KiB) Viewed 13523 times
Rush68
Post by Rush68 »
Hello everyone, thanks to everyone, it is noted that in this forum is supported, I already solved it were thermistors, thanks for your help
