+ 10 mm Z axis at beginning printing
Hello everyone, I have a PI3 PRO C, SW 1.0.04.
The problem is the z axis: when print begins, it starts at 10 mm above the bed.
I use Repetier.
Any idea?
Thanks.
I use Repetier.
Any idea?
Thanks.
Re: + 10 mm Z axis at beginning printing
Hi, Have you leveled the hot bed before printing?
Yes, the bed is leveled and the home point is perfect.
Here you have a video https://youtu.be/F53eqbg-bfQ
Thanks.
Thanks.
- WhatsApp Image 2019-06-01 at 1.46.14 PM.JPEG (127.71 KiB) Viewed 15023 times
Hi, You can adjust the z-axis height by manual adjustment or by the slicing software. Manual adjustment requires moving the nozzle to the middle of the print bed and zeroing the Z-axis. Make sure that the nozzle does not touch the hot bed or is too far away from the hot bed. A preferred condition is that when the consumable is extruded from the inside of the nozzle to the hot bed, the consumables on the hot bed are not cylindrical but have been crushed. On this basis, adjust 0.05mm each time until you try the most suitable height.
I hope this can help you.
''Manual adjustment requires moving the nozzle to the middle of the print bed and zeroing the Z-axis'' I can't figure how to zeroing
Please be more specific! Thanks.
Hi,you can use the manual controls in the slicing software to adjust the position of the z-axis.
I didn't succeed!
Please make step by step tutorial.
Thanks!
Thanks!
- Capture.PNG (60.8 KiB) Viewed 14935 times
Hi, you can do this to move the Z axis.
Well, I upgraded firmware to 1.1.8. Now on LCD main screen Z is blinking. The manual commands from any printing software not working anymore
